cigarette lighter
Jim the Box
cigarette lighter
Post by Jim the Box » Sat Oct 13, 2012 6:34 pm
How do I remove the front cigarette lighter as it's now working,
"Today's rain is tomorrow's Whisky"
Re: cigarette lighter
Post by Simon Jones » Sat Oct 13, 2012 7:17 pm
Why would you want to remove it now it's working? :wink:
Jim the Box
Post by Jim the Box » Sat Oct 13, 2012 8:58 pm
Jim the Box wrote:How do I remove the front cigarette lighter as it's now working,
Sorry should have read "Not Working", hit the wrong key, :oops:
Post by g8dhe » Sat Oct 13, 2012 9:20 pm
Jim the Box
Post by Jim the Box » Tue Oct 16, 2012 12:01 pm
My lighter socket is mounted down by the RH side of the consul not on the dash so may be different I don't know any advice ?
Post by g8dhe » Tue Oct 16, 2012 12:24 pm
Depends what you call what I guess, the normal lighter on all models is mounted on the dashboard moulding to the left of the steering wheel beside the front cubby box, ignore the red circle Image I call that area in the picture the Dashboard.
Jim the Box
Post by Jim the Box » Wed Oct 17, 2012 9:12 am
You're correct Geoff, that is where it is mounted, removed it as per instructions, and I am awaiting delivery of a replacement, I have not checked the supply voltage yet, but wanted a new unit anyway as this one looks pretty knackered. I hope I can get away with just plugging the unit in and it works first time :-?
Jim...
Post by g8dhe » Wed Oct 17, 2012 9:57 am
Not quite sure what you mean that you haven't checked the voltage ? There all 12 volts in cars/vans, you might get 24 volts in a lorry I guess but the sockets are identical. If your having problems with the supply from a socket then that's a different matter, the original units have an in-built fuse at the rear but its not a requirement to have in anyway.
Jim the Box
Post by Jim the Box » Wed Oct 17, 2012 3:16 pm
Jim the Box wrote:You're correct Geoff, that is where it is mounted, removed it as per instructions, and I am awaiting delivery of a replacement, I have not checked the supply voltage yet, but wanted a new unit anyway as this one looks pretty knackered. I hope I can get away with just plugging the unit in and it works first time :-?
Jim...
What I mean Geoff is, I'm assuming it is the lighter unit that is faulty and not the 12v supply voltage. I want to fit a new unit anyway so i'm hoping it just connects up and works. If it does not then I'll have to check to find the problem and make sure I have a supply voltage.
I am hoping to also take a feed to my new temperature sensor unit (TM-2), which I have yet to fit, and as the lighter unit supply is fed from the ignition, it would be ideal to connect or tap into the same supply cable, as I plan to fit the unit right next to it.
