intermiten right indicator
pdo123
Post by pdo123 » Thu Oct 18, 2012 9:01 am
hi guys any body come across this problem, i seem to have a right indicator intermiten problem.
one day its working the next its not. at first i thought it might be the relay but i regrudge paying 55 quid for anew one from mazda until im sure, has thisproblem via the hazards lights aswel put these on only the left works. ?switch ?earthing problem.
Re: intermiten right indicator
Post by g8dhe » Thu Oct 18, 2012 10:22 am
Given that the fault appears both with the indicator switch and the Hazard light switch it suggests that the problem is either the module or the wiring from the module to the lights themselves. As a first step make sure that the connector F1-01 is plugged in correctly, the module itself appears to be mounted on the offside, high up in the drivers footwell, circuit and locations listed below;
David Edwards
Post by David Edwards » Fri Oct 19, 2012 9:56 pm
hmmm mine is like that, it's working, its not, its working its not,lol
