Metal coolant pipes
al & chris
Metal coolant pipes
Post by al & chris » Thu Nov 01, 2012 6:41 pm
We have a coolant leak from metal pipe work under van just behind drivers door where a flexible hose joins it. Any ideas where we can get these metal pipes from.
Re: Metal coolant pipes
Post by rita » Thu Nov 01, 2012 6:52 pm
Post by Muzorewa » Thu Nov 01, 2012 7:15 pm
Or Warrington Mazda :wink:
http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=58378
Ring Shanil on 01925 428755, she knows her stuff. If it's the same as mine (sounds like it) you need part 61-2D1 off the heater pipes chart, she might email you an exploded diagram to be sure it's the right bit you're ordering. They won't have it in stock but they can get it next day from Belgium (don't ask)
al & chris
Post by al & chris » Tue Nov 06, 2012 5:05 pm
Thanks just rang Shanil today and ordered part.
Post by Northern Bongolow » Tue Nov 06, 2012 6:41 pm
enjoy fitting it. :shock: .
top tip.
dont remove the the big black air pipes from the chassis/airbox if you can help it, they are mounted on little rubber mounts, when you try to remove them they tear off.
al & chris
Post by al & chris » Sat Nov 17, 2012 6:15 pm
Thanks all now fitted by our local garage. Took advice on air pipes. Holes in pipe in exactly same place as Muzorowas think that area is exposed to elements more than rest of pipe. :) :D
ADAMD
Post by ADAMD » Tue Nov 27, 2012 1:54 pm
This pipe is on its way out on my Bongo,
Does anyone have any photos or any fitting tips in addition to those above?
Also can anyone tell me the price of the pipe from Warrington Mazda?
Many thanks
Adam
Post by Muzorewa » Tue Nov 27, 2012 2:35 pm
The ATF pipe was £83.01 + VAT (total for both pipes as they're stuck together with clips) and the coolant pipe was £44.35 + VAT.
Post by Northern Bongolow » Tue Nov 27, 2012 6:45 pm
ADAMD wrote:This pipe is on its way out on my Bongo,
Many thanks
Adam
i jacked the front up on this as the water pump was being replaced and the stat, but as long as you jack either end up high, if not over a pit, it will allow you the ness room to twist and thread the pipe into place as it runs from the rear heater to the front axle just inside the offside chassis rail, there isnt a lot of room but its do-able. you will have to bleed the system after too.
Bongo??
Post by Bongo?? » Wed Nov 28, 2012 1:33 am
Northern Bongolow wrote:enjoy fitting it. :shock: .
top tip.
After fitting your nice new pipes these black air pipes come in very handy to attach a couple of large universal mudflaps to,on their side,to protect the area from all the road dirt that gets thrown at them and will hopefully allow them to last a lot longer!
The way i fitted them under my van also keeps the rear heater hoses away from the offending road dirt,stones,clart etc! :wink:
Year 2000 V6
