Crank pulley
Crank pulley
Recently i have noticed a metallic rattle when the engine is running so had a look today and found that the crank pulley has separated with the back half coming away from the rubber mount. Question is. Is this repairable or do i need a new pulley? Also does anyone know the size of the crank bolt. The largest socket i got is 36mm and thats a bit to small.
You know when you've been Bongo'd .
Re: Crank pulley
The part that has separated is a damper built into the pulley I reckon you will need a pulley,don't know what the bolt is
Re: Crank pulley
Thanks for that. Priced a 2nd hand one up £50 +vat.the laird wrote:The part that has separated is a damper built into the pulley I reckon you will need a pulley,don't know what the bolt is
Re: Crank pulley
Hi Andy W,
38mm socket for the crank bolt.
Re: Crank pulley
Nice one! Thanksrita wrote:Hi Andy W,
M 80NGO
- Location: Usually in My own wibbly wobbly lill world ! Otherwise Huntingdon.
Re: Crank pulley
You'll also need a locking tool to hold the pulley while u tighten the 38mm bolt Probs easier to bung a garage £20 to fit it for you.
Re: Crank pulley
Andy W wrote:Thanks for that. Priced a 2nd hand one up £50 +vat.the laird wrote:The part that has separated is a damper built into the pulley I reckon you will need a pulley,don't know what the bolt is
try bongobits4u2012 or 200bhpcars, both these guys will help.
- Simon Jones
Re: Crank pulley
Andy, I've dropped you a message regarding a spare pulley. If you'd like it, please let me know ASAP as I'll have to source 38mm socket to get it off
Re: Crank pulley
PM sent.Simon Jones wrote:Andy, I've dropped you a message regarding a spare pulley. If you'd like it, please let me know ASAP as I'll have to source 38mm socket to get it off
- Simon Jones
Re: Crank pulley
Cheers Andy - will get that sorted for you
- Simon Jones
Re: Crank pulley
A quick q: is it left hand or right hand thread? I'm guessing its standard: lefty loosy righty tighty
Re: Crank pulley
Don't know as i haven't tried to take it off yetSimon Jones wrote:A quick q: is it left hand or right hand thread? I'm guessing its standard: lefty loosy righty tighty
