Reverse beeper
RobEvans
Reverse beeper
Post by RobEvans » Thu Feb 14, 2013 7:20 pm
Hi I'm going to fit parking sensors and would love to know how to disable the reverse beeper. I have searched but said topic not found any help will be much appreciated cheers rob
Re: Reverse beeper
Post by g8dhe » Thu Feb 14, 2013 7:28 pm
Break the Red with Yellow striped wire running into the Sound Warning System module, its on pin F of the connector;
RobEvans
Re: Reverse beeper
Post by RobEvans » Thu Feb 14, 2013 8:14 pm
Cheers for that. The sounder is in drivers side footwell?
Gixermark
Re: Reverse beeper
Post by Gixermark » Thu Feb 14, 2013 10:11 pm
Mulletman wrote:Hi I'm going to fit parking sensors and would love to know how to disable the reverse beeper. I have searched but said topic not found any help will be much appreciated cheers rob
I Added this to another thread a few weeks ago :
"Just to confirm for anyone else who hates the reversing beep from under the drivers footwell, the following DOES work as I've just done it on my 96 'N' reg :
Quote "Hi,if you only want to stop the reversing bleeper,remove the red wire with the yellow tracer (ON THE PLUG)"!
Soooooo.....remove the panel by the drivers right foot, look for a large blue multi connector ( was on my '96 model! ) then find the red wire with a yellow tracer/strip. Cut this wire & the reverse beep is silenced forever .... AFT, lights on, keys in ignition etc still make beeping sound!
=D> =D> =D> :D
RobEvans
Re: Reverse beeper
Post by RobEvans » Thu Feb 14, 2013 11:19 pm
