02 lambda sensor 2ltr petrol
Droogle
Post by Droogle » Fri May 10, 2013 11:21 am
I have the engine check light illuminated on the dash and my local mechanic has advised it is the 02 lambda sensor that is faulty , Cany anyone advise of the correct part number or a compatible part.
Thanks :D
Re: 02 lambda sensor 2ltr petrol
Post by teenmal » Fri May 10, 2013 12:24 pm
FEMJ18861.
And here for compatible.
http://www.autopartoo.com/oem/126611.html
Droogle
Post by Droogle » Sun May 26, 2013 11:14 am
Thanks for the information , do you know where I could buy one from .
:D
jem
Post by jem » Mon Jun 24, 2013 4:16 pm
In case you have not sorted it yet, I just replaced mine with this one I got on eBay
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... OC:GB:3160
My crimping was bad, so I redid it with terminal block and it is now fine, used old film canister & insulting tape to protect it.
Jem
Droogle
Post by Droogle » Thu Aug 01, 2013 8:52 am
Jem, Thanks for the information Was originaly quoted £90 getting the part myself meant it got done for under £40 all in , Engine light now off and hopefully will get another 1mpg ...... :D
