As I intend to buy a V6 Bongo I was wondering if anyone knows of a good source for a stainless steel twin system exhaust? You know, 3 into 1 on each side, down to and including the rear back boxes. I had this setup on a V8 Ford and it sounded great. They are sometimes alternatively called extractors, or they were in Oz where I had mine.
Cheers.
V6 twin exhaust system
Moderator: Ian
- Simon Jones
Re: V6 twin exhaust system
You would have to come up with a solution for the lambda sensor as that is fitted before the cat after the two main manifolds have joined up. If you do find a solution, let me know as I would like a twin exhaust too
