Whistling engine and sediment light
TonyW
Post by TonyW » Sat Sep 28, 2013 10:31 pm
Hi all,
2nd post here!
Two questions .....
1) We have a 1995 2.5 diesel auto Bongo. Is it usual for their to be 'whistle' type noise on acceleration at and over 2000rpm. Methinks it's the turbo and it's OK but anyone like to confirm my very untechie know-how?
2) The 'sediment' light comes on ignition but immediately goes off .... is this OK?
Ta muchly in advance for any advice.
Cheers.
Tony.
Darkstar
Re: Whistling engine and sediment light
Post by Darkstar » Sat Sep 28, 2013 10:43 pm
whistling may be No1 exhaust stud broken, not had the pleasure myself but plenty about it on forum,
check light? will be on permanent if water needs draining from filter.
Got a Bongo for the Wife, Best trade-in ever
Post by Northern Bongolow » Sat Sep 28, 2013 11:19 pm
TonyW
Post by TonyW » Sat Sep 28, 2013 11:41 pm
Thanks Darkstar and Northern .... IF this is the issue .... great :( ..... only had this since Weds evening and that sounds like a major job that I (a non-techie) would struggle with greatly. Off to a recommended service centre I reckon. Thanks again.
Post by Northern Bongolow » Sat Sep 28, 2013 11:46 pm
sorry mate.
have a look for the missing or loose no1 stud shown in the above link, or the sooty marks around the area.
TonyW
Post by TonyW » Sun Sep 29, 2013 12:33 am
If it is this problem ..... is it a problem driving it before it's sorted?
wonkanoby
Post by wonkanoby » Sun Sep 29, 2013 10:19 am
no
TonyW
Post by TonyW » Sun Sep 29, 2013 10:27 am
Thanks Wonkanoby for that comprehensive response ;)
wonkanoby
Post by wonkanoby » Sun Sep 29, 2013 10:29 am
faster you get it fixed though the less it can twist and get out of shape
TonyW
Post by TonyW » Sun Sep 29, 2013 8:49 pm
Hmmmm ...... no sooty deposits, no exhaust fumes in cab and no studs missing???
Also, just had new; cylinder head, new set of valves, new headgasket set.
Not convinced it's this problem. Do Bongo turbos 'whistle' ?
Thanks.
wonkanoby
Post by wonkanoby » Mon Sep 30, 2013 2:22 am
are the clip screw on u shaped pipe on turbo tight
Post by mikeonb4c » Mon Sep 30, 2013 8:11 am
My Bongo often whistles a bit. I've always assumed it was the turbo and have long stopped noticing it. Exhaust studs have been described as a bit more like a shriek when revved hard though never having heard it, I wouldn't know.
TonyW
Post by TonyW » Mon Sep 30, 2013 9:29 am
Thanks Mike and Wonka ..... I'll take a look at that turbo pipe clip
