Central Locking Problems
windywatson
Post by windywatson » Mon Sep 30, 2013 2:20 pm
Hi all, My vehicle hadn't got a central locking fob when imported. I got around the problem by using the fob for my second Bongo. This was easily done by removing the drivers side door card and then holding in the rest button on the central nocking module whilst holding down the button on the fob so that the system learnt the frequency.
The big down side was having to share the fob between 2 vehicles. Also due to the proximity of the camper to my day van when unlocking the van I would often end up unknowingly leaving the camper unlocked when leaving home.
So I've purchased from a breakers a second hand Central locking receiver & fob (matched obviously) and have swapped them out into my day van. The central locking works fine with the exception of the following.
If the vehicle is left unlocked the system will lock the vehicle within a couple of minutes. This is great if you are forgetful. However it still does the same if you have unlocked the vehicle got in and driven off. Which might seem like a good safety future, but a pain having to unlock the doors to get out.
My other van doesn't do this, so I expect this is a later unit.
Question, does anyone else's do the same & is there a method of programing the system to alter the way it is locking?
Windy-Watson
2001 V6 Tin Top
Re: Central Locking Problems
Post by Simon Jones » Mon Sep 30, 2013 6:42 pm
The later units do lock again if a door isn't opened within a short period after unlocking. However, it should not lock the doors once on the the move. It sounds like its not getting the signal that the door has been opened or it may need a signal to detect the ignition is switched on.
windywatson
Post by windywatson » Tue Oct 01, 2013 9:22 am
I do have a courtesy light delay unit that I have fitted. Wonder if that could be the cause? Any ideas if that may be effecting it?
Windy-Watson
2001 V6 Tin Top
Post by g8dhe » Tue Oct 01, 2013 11:22 am
You can't rule it out that's for certain, time the delay and compare it with the door locking.
