Many thanks in advance. (
Lights on bullbar
- kingbillybongo
Lights on bullbar
Can any one give me any tips on how to wire in spot lights on a bullbar
Electrical novice
[color=#0000BF]billybongofreedom[/color]
Re: Lights on bullbar
They have to be wired to only come on with the main beam headlamps
- helen&tony
Are they the Mazda Cibie yellow ones , original equipment accessory type? as if so, they are foglights, not spots, and not spots....so, as such, they would need wiring in to switch on with dipped beam
- Dr Fingers
If they're yellow fogs, then they should surely be wired to come on with the other fog lights??
I have the Cibies. Unfortunately I assumed it was the bulbs that are yellow, but actually it's in the glass. I want mine on full beam with white light for extra full beam power, so will have to change the Cibies for something else. I also have them wired to their own on/off switch on the dash, so I can use them only when really necessary.
Derek
Derek
- helen&tony
Hi Derek
The yellow Cibie fogs are clear glass,but there is a little glass or plastic capsule which fits over the bulb which makes them yellow. They're actually quite good as fogs, and you could have a selector switch to choose which pair you want on....the low ones in the bumper, or the ones on the Bullbar. I replaced my Cibies with a pair of KC Daylighters spotlamps...very nice at 100 watts each and driving light pattern....essential over here as there are no road markings or street lights in the country
