rear heater fan
rear heater fan
Just fit new rad and long o/s metal pipe which goes to rear heater , bled system etc, all hoses hot, temp stable, bubbles appear to have stopped but for some reason rear fan has stopped working, now is this a coincidence or have I done something wrong, and could it just be the fuse. Cheers
- Simon Jones
Re: rear heater fan
Likely to be a coincidence. Check the fuse and also double check you've got the 'rear' switch on up front.
Re: rear heater fan
Hi simon, hope so, and wot do you mean exactly, thanksjase
- Simon Jones
Re: rear heater fan
If you have manual controls, there will be a rocker switch marked 'fan' or 'rear' to the right of the steering wheel. If you've got digital controls, there will be a push switch marked 'rear' on the panel. Without this being switched on, the rear fan will not work.
Re: rear heater fan
Ahhh right, ill have to check, its an Nreg manual 2.5td tintop if that makes any difference, many thanks simon
- Simon Jones
Re: rear heater fan
It'll be one of these then: http://www.ebay.co.uk/itm/Mazda-Bongo-T ... 43c043c012
Re: rear heater fan
And switch on the front fan.
Re: rear heater fan
we have all done it sometime
