Wheel Nut Removal Tip
Post by Bob » Thu Nov 28, 2013 1:33 am
In the unlikely event that your standard Bongo wheel brace fails to remove the nuts its worth knowing that a 14mm spark plug socket will fit.
14mm Is the thread size, not the nut size (21mm) and the long socket will nicely move the bar out a little. :wink:
Edit: This is also true for the MX5. Bloomin' big nut for a small car. :shock:
