Thank you
Memory foam mattress
Moderator: Muzorewa
Hi...I'm getting my new bongo on Tuesday....yippee! I'd like to get a memory foam mattress, can I close the roof with it up there and if so how thick should it be to close properly?
Thank you
Thank you
Re: Memory foam mattress
You can but specific ones for bongos on
eBay. They are quite thin though. I would say
One of those plus an inflatable mattress
Would be best. That's what I use.
Ok thank you!
Just looked....they look great. Thank you!
I have been looking at getting a memory foam mattress for the roof, have you bought one yet? If so what is it like? Is it any good
Poundstretcher is the best value I've found for these. £29.99 for a double if I remember correctly. I use two up top because the base is a bit firm, but one is adequate below. If you're feeling imaginative they would be easy to cut an insert out of for the roof hatch, but I've never bothered.
1995 Bongo Auto Freetop, owned since November 2011.
We have just had one from these guys too:
http://www.comfortzleisure.co.uk
We can certainly recommend them. The memory foam matress we needed was made to suit our van as it has the catflap conversion and they could not have been more helpful .
Andy
Andy
