Bongo has failed MOT on something that sounds simple.
Quote!  Near & Offside anti roll bar joint dust cover excessively worn allowing dirt ingress?
Can I buy these at the Bongo shop?  I gather I will have to drop the link to fit them so should I renew these also while I am on?
Thanks in advance
									Bongo MOT failure
Bongo MOT failure
						- mikexgough
Re: Bongo MOT failure
Anti Roll Bar joints are the Drop Links.... whack a new pair on...sorted..
Seems to be talking only about anti roll bar dust covers?  I will order a couple anyway
I guess the so called cover come with it then?
cheers
cheers
Can anyone post a schematic on this please so I can understand cover?? last drop links I fitted were on a comb van and there were no covers??ELZE wrote:Hi
Thanks in advance
just put two new front antiroll droplinks on last month before my MOT. The covers are an integral part of the rose joint on the droplink, so if they have gone, it will be new links. also fitted new bushes to the antiroll bar mounting. did make it feel a bit better.
1996 2.5td aft 2wd
1996 2.5td aft 2wd
Thanks for this. Just ordered two heavy duties from Bongo shop, don't want to do this again hopefully not!pc13cb92 wrote:Hi,
1996 2.5td aft 2wd
Hi Mike, really easy job, I did mine on the drive in less than an hour, If you need a hand give me a shout.
stuc wrote:Hi Mike, really easy job, I did mine on the drive in less than an hour, If you need a hand give me a shout.
Thanks Stu
It needs retesting anyway so i have booked it in on Sat morning and retest Sun. I just went for the heavy duty drop links from the shop which arrive tomorrow.
I have PM/d you
