Odometer not working
Hello Guys,
Got an issue and was wondering if you can help.
Odometer stopped reading mileage, great but I have LPG and use it to measure fuel. The RPM/Speedo and everything else works just fine on the dash but no the miles, any thoughts?
Is there a cable to reconnect or fuse to replace ?
Thanks.
Thanks.
1997 2.5 V6 + LPG
Re: Odometer not working
Try pushing the reset (sharply) a few times, if it doesn't cure it check the plug at the back of the speedo head.
PS, are all the wheels inline.
Took the dash off but A didnt know what I was looking for B was scared I broke it!
Will try again and see if I can see the speedo cable. But would one hting break without the others?
Wheels? Unless I hit a big pot hole I cant remember nothing has changed from last week when it was working.
1997 2.5 V6 + LPG
no he means wheeels show the milage,at certain points the can get stuck,wiggle them
- Simon Jones
There is a single (electrical) wire from the gearbox to the instrument panel which drives the speedo and odometer. If the speedo is fine, it would suggest the odometer itself is faulty.
Wiggle them as in jack it up and wiggle the free wheels? Needs the tracking checked anyways, you think this may do it?wonkanoby wrote:no he means wheeels show the milage,at certain points the can get stuck,wiggle them
Sorry for the thick questions!
1997 2.5 V6 + LPG
no the actual numbers on the speedo...they are a bunch of wheels or rotors
wonkanoby wrote:no the actual numbers on the speedo...they are a bunch of wheels or rotors
I get it - now I just fell dumb, doh! Will go stick a screw driver in it and see how it goes.
1997 2.5 V6 + LPG
This turned out to be a duff speedo. Working fine now thanks for everybody's help.
1997 2.5 V6 + LPG
wow that took you 4 months to find out ha ha
ha ha good for you
