Roof board.
Jonny Tunnel
- Bongonaut
Roof board.
I have recently bought a Bongo, but the rear roof board is missing. Can anyone kindly tell me the dimensions, and what material i should use to make one please.
Also, what is the red switch to the right of the button below steering wheel next to switch that says 'Rear'.
Kind Regards
Kind Regards
- Simon Jones
Jonny Tunnel
- Bongonaut
Re: Roof board.
Yes its an AFT roof as shown in your pic. The board is missing, perhaps somebody yanked it off.
Thanks also for advice re: switch.
I'll prob make a temporary board out of ply.
Regards Jonny
Regards Jonny
- Simon Jones
Re: Roof board.
Theres one for sale here: http://www.ebay.co.uk/itm/mazda-bongo-e ... 233a48f5f2
You may also need the gas struts if the whole lot has been removed.
Jonny Tunnel
- Bongonaut
Re: Roof board.
No its the internal part of the roof that i need, rear section.
Thanks anyway
Thanks anyway
- Simon Jones
Re: Roof board.
I can't visualise the part you mean. There's only the removable front section and lift up panel with the integral hatch. Can you highlight which part it is on this diagram?
http://lushprojects.com/bongopartsmk2/c ... 1of02.html
Re: Roof board.
Is it the floor covering panels you are looking for.........69-8R3/69-8R2A ETC
Jonny Tunnel
- Bongonaut
Re: Roof board.
Yes this is correct, rear floor panel. Sorry i didnt explain well, i dont have a manual yet to help either.
Jonny Tunnel
- Bongonaut
Re: Roof board.
Yes looks like 69 8r2a.
Re: Roof board.
Your best bet would be to contact a breaker, cant imagine that they will be expensive, not a lot of call for this item.
Good Luck.
Good Luck.
Jonny Tunnel
- Bongonaut
Re: Roof board.
Thanks Rita, i'll have a look for breakers!
- Simon Jones
Re: Roof board.
The parts shown as 69-8xxx are grey headlining material panels which are like pieces of felt or carpet glued to the inside of the AFT. Can you post a photo showing where the thing you are looking for should go?
Jonny Tunnel
- Bongonaut
Re: Roof board.
Hi not sure how to put up photos, have u an email i could send pic please.
cheers Jonny
cheers Jonny
- Simon Jones
Re: Roof board.
PM sent
- Simon Jones
Re: Roof board.
Thanks for the email Jonny. The item you need is the front roof board which fits over the front cab section. It is drawing number 57-480A in this diagram. You'll probably be able to get one from a breaker. Update you profile with your location & we can probably recommend somewhere close to you. If you get stuck, I know a man who will probably have one
