1996 2.5 TD 4WD I have that on off steering tightening under normal conditions. I have attributed this to the bottom UJ. I have searched the web to locate a replacement - the only one I located so far was from Vosper of Plymouth at just under £84 all in.
Coincidentally the part 32-850A keeps cropping up as a Skoda part with the same ID 32-850A.
Just wondering if anyone has located a reasonably priced clone?
Lower steering UJ
- Bongonaut
Re: Lower steering UJ
If there is no play in the joint, try using some spray grease - cover the UJ in it.
As a matter of interest is the top uj ok ?.
- Simon Jones
Note: 32-850A is the drawing number NOT the part number. It's
S10H32850 32850A JOINT(NO.2),STEERING
Ene is at the bodyshop for now having some surface rust sorted.
