Hello
My AFT switch is a bit dickie, but trying to remove the little sucker is proving difficult.
I don't really want to remove the headlining and push it out from behind.
The switch won't come out of the grey plastic escutcheon.
And, the escutcheon makes some 'could be expensive to repair' type noises if I try to remove it and the switch from the headlining when the lining is in situ.
Anyone any tips?
Thanks in advance.
Martin
Any tips for removing the AFT raise lower switch?
Buxtonbongo
- Apprentice Bongonaut
- Simon Jones
Re: Any tips for removing the AFT raise lower switch?
You just lever the whole thing including the grey escutcheon. Should pop out quite easily as I recall, although if there are spring clips, you may need to push them in first using something like a credit card. I've got a spare switch at home which I can take a photo of later if you're still struggling.
