Rear Drop Links
Rear Drop Links
Can anyone tell me which Ford Galaxy model year rear drop links fit on the Bongo?
I got the info from the compatible parts list and it just says Ford galaxy but not which model.
I just got some Vectra front drop links this morning from Euro car parts OE spec for £15 the pair. Worth trying for that much i think.
Re: Rear Drop Links
Don't know about the galaxy ones but heard the Rover 800 are a near fit, what length were the front links that you got from Eurocarparts..
Re: Rear Drop Links
Same length as one's that came off, it was 2005 vectra ones that I got. I might take a rear one off and see if Euro car parts can match it. I will report back when done.
Done front and rear anti roll bar bushes and front drop links today, Van feels much better no knocks now.
Re: Rear Drop Links
stuc wrote:Same length as one's that came off, it was 2005 vectra ones that I got. I might take a rear one off and see if Euro car parts can match it. I will report back when done.
Do you have the length at the moment, making adjustables and don't have the vehicle to check.
Re: Rear Drop Links
245mm from centre to centre of the ball joint.
I have the old one if you need it.
This is the front one though.
Re: Rear Drop Links
Thanks very much, appreciated.
Re: Rear Drop Links
Hi Rita, just out of interest why would you want adjustable drop links?
Re: Rear Drop Links
stuc wrote:Hi Rita, just out of interest why would you want adjustable drop links?
Ditto
Re: Rear Drop Links
Ok, I had a friend (not many) that required two links urgently MOTT, I had two I think they were SAAB adjustable in the workshop but did not have the data to set them to the required setting.
THANKS STUC
THANKS STUC
