Having inspected the rear brake pads on one wheel so far, I noticed that there's just one spring type clip that slots into the 2 holes at the top end of each pad. The holes at the bottom of the pad are empty with no clip. Is this correct ? If not is there any consequences to the bottom holes being without a spring and if so where can I get replacement a spring from ?
Thanks in advance.
Rear Brake Pads - Spring Clips That Fit Holes in Pads ?
- Bluespanner
Re: Rear Brake Pads - Spring Clips That Fit Holes in Pads ?
one per side sounds right to me
pads sort of pivot when the cylinder pushes
and would not be able to if more than one
- Bluespanner
Cheers Wonkanoby.. That's one less thing to worry about
