Coolant alarm orderered, an easy fit for a novice?
BongoBongo123
Post by BongoBongo123 » Tue Jul 08, 2014 5:39 pm
The £78.95 one from Haydn. Is this a complex procedure ? Does it come with instructions and is there a members area guide? Thanks 8)
They call me light foot.
Gasy
Re: Coolant alarm orderered, an easy fit for a novice?
Post by Gasy » Tue Jul 08, 2014 5:55 pm
It just needs an ignition live and earth from inside cab
Unit mounting in cab somewhere
1 or2 wires going into front engine Bay Area there is a big rubber grommet behind glove box pierce and thread thro
Easy to use a "piggy back fuse "to get live from fuse box next to knee
BongoBongo123
Post by BongoBongo123 » Tue Jul 08, 2014 5:57 pm
Great found the data sheet on that as well, good stuff man. =D> I think I might even be able to that, lol. Am I right in thinking you need to drill a hole in the expansion tank... hmm.. seems a tad dodgey.
Oh well will have a good look at it all.
winchman
Post by winchman » Tue Jul 08, 2014 6:20 pm
Its really easy I think it even comes with the correct size drill
Post by haydn callow » Tue Jul 08, 2014 7:50 pm
It comes with full instructions and everything you need to fit it......any problems and we are on the end of the phone.....drilling the tank does sound a bit daunting but fear not, we have had thousands fitted and never a problem
BongoBongo123
Post by BongoBongo123 » Tue Jul 08, 2014 8:07 pm
haydn callow wrote:It comes with full instructions and everything you need to fit it......any problems and we are on the end of the phone.....drilling the tank does sound a bit daunting but fear not, we have had thousands fitted and never a problem
Cool I am fairly methodical so should be ok. Just wonder where an obvious ground with easy to attach earthing point might be.
