starting problem...some advice please
2newbies
Post by 2newbies » Fri Jul 11, 2014 7:17 pm
Hi everyone, went to start Daisy this morning,turned the key the orange light went out, she turned over fine but would not start ,I left her afew mins then tried again, this time she sprang into life on the first turn of the key.........any ideas,I should mention this did happen once before.. as the SB looked alittle sad i replaced it ,thinking that as the cause.....thanks Paul
Steptoe
Re: starting problem...some advice please
Post by Steptoe » Fri Jul 11, 2014 9:17 pm
Glow plug relay, or the plugs themselves?
Maybe a slight air leak into the fuel line, meaning that the fuel runs back towards the tank when the engine is stopped. Had something similar on a Xantia, when the diesel return pipes between the injectors had started to perish.
Tony x
Post by Tony x » Sat Jul 12, 2014 6:20 pm
If the issue is an air leak, it might be worth seeing if the Bongo starts easier after being left pointing down a hill rather than up it.
2newbies
Post by 2newbies » Sat Jul 12, 2014 7:18 pm
Hi, thanks for the replies,I think I will start with a new glow plug relay.....blimey there not cheap are they!
Post by g8dhe » Sat Jul 12, 2014 11:11 pm
Rather than replace the relay, start by measuring the voltage on the Glowplug bus, if that is low then look towards the connectors and then only after that at the relay! If you don't already have a multi-meter then its a lot cheaper than a new relay!
See something like this http://www.maplin.co.uk/p/uni-trend-ut3 ... eter-n15by
philpdr
Post by philpdr » Sat Jul 12, 2014 11:49 pm
When you turn the ignition on,wait until you hear a distinctive click from the relay before cranking over.Can be a good 30/40 secs after the glow plug light has gone out.
Post by teenmal » Sun Jul 13, 2014 12:03 am
If your engine does not start owing to the glow plugs/heaters not working (in this weather)I think you need to look at the overall condition of the engine.
2newbies
Post by 2newbies » Sun Jul 13, 2014 1:35 am
thanks for all advice,I've had dasiy for over two years now ,apart from a leaking radiator and water pump when I first got her ,no probs at all {6000 miles) I did 320 miles in one day last month, I don't think I need to look at anything major as far as the engine is concerned,,,,,I think I will start with changing the glow relay....is it easy to do.
