drivers side inner wing relays S reg diesel.
Post by Northern Bongolow » Mon Jul 21, 2014 6:45 pm
whilst changing the gearbox oil on muzzes S reg diesel we ranged through the gears and park etc and noticed that a relay on the drivers side inner wing was activated with every stick movement to and from every selection. this is a new one on me, anyone any ideas what its doing #-o #-o #-o 8)
Re: drivers side inner wing relays S reg diesel.
Post by Northern Bongolow » Tue Jul 22, 2014 9:38 pm
anyone ??? :)
Post by Simon Jones » Tue Jul 22, 2014 10:14 pm
Only relay I can see on drivers wing is glow plug, but cant see it would be that: http://lushprojects.com/bongopartsmk2/c ... mgno=.html
Post by Northern Bongolow » Tue Jul 22, 2014 10:41 pm
i will ask muz to photo them------ there is more than one on his driverside inner wing.--------very strange, maybe geoff could help. [-o< :wink:
Post by Muzorewa » Wed Jul 23, 2014 5:44 am
Will take photos this evening :wink:
Post by Muzorewa » Wed Jul 23, 2014 5:52 pm
Well here they are, they're tucked away beside the starter battery. There are three, the one nearest the headlamp does all the clicking when the gears are worked.
Gasy
Post by Gasy » Wed Jul 23, 2014 7:04 pm
Mines an r reg
And I have 3 same as muz
Carnt see the top of closest one but the rear one has H310 on top of rubber cover
Didn't someone put a picture up once with them labeled on what was what
Did that have 3 on drivers side?
Post by Northern Bongolow » Wed Jul 23, 2014 7:20 pm
cheers paul.
the 3 that geoff usually shows are on the passy side if im not mistaken.
this link to a later motor shows some on the driverside, maybe muzzes is a changeover model that has later goodies added even though its old shape. #-o :wink: .
http://lushprojects.com/bongopartsmk2/c ... no=.html#6
nth
Post by nth » Thu Jul 24, 2014 8:30 pm
Maybe the inhibitor relay that stops you starting the engine if its not in P or N ??
Thats the only relay i can think of off hand that would be operated when the gear lever is moved.
95 2.5d 4WD AFT
Post by Northern Bongolow » Thu Jul 24, 2014 9:16 pm
it maybe that but the relay operates when moving from any gear lever position to any other,its got me this one. #-o :wink: .
no doubt its obvious, but #-o
Post by Simon Jones » Thu Jul 24, 2014 10:16 pm
You could always unplug it and see what happens?
Post by Muzorewa » Fri Jul 25, 2014 9:08 am
On the later ones, I think ours was one of the first, there's a gear indicator on the dash as well as the gear selector. Not that relays would be needed but might it be connected with this?
Post by g8dhe » Fri Jul 25, 2014 7:25 pm
Sorry lads only just found this been using the tablet all week and not the laptop;
The starter relay is in that position (or should be they can be moved around of course), that shouldn't be operating on gear shifts!
Next relay in is rear de-froster;
Can't see anything using the third position, but net is a bit slow out here!
Gasy
Post by Gasy » Fri Jul 25, 2014 7:31 pm
Muzorewa wrote:On the later ones, I think ours was one of the first, there's a gear indicator on the dash as well as the gear selector. Not that relays would be needed but might it be connected with this?
Mines not got the gear indicator in the dash
Mines r reg
And has the 3 relays on drivers side
