Cam belt
Cam belt
Do anybody know the recommended mileage when the cambelt should be changed on a V6 petrol 2001 reg bongo? Or has it got a chain?
- mikeWalsall
Re: Cam belt
There are two cam belts on the V6 ..
It pays to get the cam and crank seals done at the same time ..
The book says the cam belts should be changed at 100.000km .. but they may deteriate through age / contamination before that milage ..
Re: Cam belt
It's a new import 140,000 km, will have to check to see if was done at 100,000.
If the cam belt goes it will only mess up half the engine, not like our Peugeot 406!
Re: Cam belt
mikeWalsall wrote:There are two cam belts on the V6 ..
That's a new one. I always thought they only had one timing belt.
Re: Cam belt
Do u mean the new shape? It is if you mean that!
Re: Cam belt
Ohhhh I see. Oh well better keep are fingered crossed until we check it out.
- mikeWalsall
Re: Cam belt
Ooppps sorry .. not thinking .. yes it's just the one belt drives the four cams ..!!teenmal wrote:mikeWalsall wrote:There are two cam belts on the V6 ..
http://www.mazdabongo.com/catalog/clear ... belt-95-03
