We are looking for the part numbers for these items, which we assume are on page 6340A of Lushprojects. But this page is poorly translated. Anyone out there know which numbers indicated the microswitches?
http://lushprojects.com/bongopartsmk2/c ... o=.html#42
AFT Microswitches
AFT Microswitches
- Driver+Passengers
Re: AFT Microswitches
On that page, there is R1-5A1:
SWITCH,LIMIT-TOP MOTOR
S10K6987X R15A1 SWITCH,LIMIT-TOP MOTOR AN (S10K-69-87XA) - 970701
S10K6987X R15A1 SWITCH,LIMIT-TOP MOTOR SGL3 -107386 SGL5 -115873 SG5W -106397
S25D6987X R15A1 SWITCH,LIMIT-TOP MOTOR AN (S25D-69-87XA) 970701 -
S25D6987X R15A1 SWITCH,LIMIT-TOP MOTOR SGL3 107386- SGL5 115873- SG5W 106397-
It's hard to tell from the image.
I had previously identified (or thought I had at the time, at least) a suitable replacement part...
Omron D2FW-G073M (poss. D2FW-G071M)
http://www.omron.com/ecb/products/pdf/en-d2fw_g.pdf
Edit:
One source:
http://uk.mouser.com/Search/ProductDeta ... D2FW-G073M
http://www.digikey.nl/product-detail/en ... -ND/307734
Other names:
B3WZ4003R
D2FW1005A
D2FWG073M
D2FWG073M1
SW511
Edit:
One source:
Other names:
B3WZ4003R
D2FW1005A
D2FWG073M
D2FWG073M1
SW511
Hi,I hope you don't mind me "jumping on board" but I was wondering if you could you tell me which one is for the roof tent light,.....thanks Paul
We keep these bulbs in stock at the Bongo Shop. They are called "Interior Bulbs". See http://www.igmaynard.co.uk/bongo/mercha ... m#Lighting
- g8dhe
If you mean the microswitch its the offside one above the driver at the front.2newbies wrote:Hi,I hope you don't mind me "jumping on board" but I was wondering if you could you tell me which one is for the roof tent light,.....thanks Paul
