My gauge starts at 1/3rd, even when cold and pretty much stays there.
I have a modified gauge I think. I have a small black box under the dash with a screw adjustment for the alarm based on temperature.
First thing to check. Sender?
temperature gauge stuck.
- Simon Jones
Re: temperature gauge stuck.
The box you describe sounds like a Mason alarm. Very good little unit and not known to be problematic. You could disconnect it to eliminate it being the cause. I've probably got the wiring details somewhere if you need it.
Yeah. I'll test the sender first. I'm guessing I'm looking for something plugged into the rad.?
- mikeWalsall
No ..
It's a device connected to the temp guage to buffer / and manualy adjust a pre set temp alarm ...
http://www.townace.plus.com/ie/ietefibo.pdf
Sadly though .. no longer available ..
Dodgey wrote:Yeah. I'll test the sender first. I'm guessing I'm looking for something plugged into the rad.?
The sensor/sender is situated at the top front o/s of the cylinder head.
18-510 here.
Dodgey, what setting is the unit set at,I think this unit has an OFF switch,don't know if the off switch would cause this reading.
