alarm icons for your dashboard:http://tinyurl.com/m3wwonz
I discovered a gubbins called "Magic Camber": http://www.monroe.com.au/products/magic-camber.html
This appears to adjust the alignment of the upper strut bolt thereby correcting the camber of the wheel in question....
Anyone used one of these? It might be risky to suggest using them to give greater front wheel negative camber to
improve holding when getting the arse end out on high speed corners (with the aerodynamics of a 40ft container? surely some mistake?)
Dr B
