Coolant hoses are jubilee clip suitable
bongobridge
Post by bongobridge » Thu Oct 23, 2014 9:05 pm
Hi all,
I have been fighting with a dripping hose at the bottom of the rad for a while now , changed the hose but seem to get the same leak but not as severe (for a while ).
Question is
Are jubilee clips suitable for these hoses ( original clips long gone ). If not what do you use?
Or anything that can used be on the tube to help for a better seal.
Getting fed up topping up .
Ta
Nick & Jen
[color=#FF8000]life's a beach, then you fry[/color]
Re: Coolant hoses are jubilee clip suitable
Post by Ian » Thu Oct 23, 2014 9:44 pm
Go to a Mazda dealer and ask for part number 9WNC-B3-700B. They are the Mazda originals and not jubilee clips.
Post by Bob » Thu Oct 23, 2014 10:37 pm
Or Ian Taylor may be able to help out.
Post by mikeonb4c » Thu Oct 23, 2014 10:59 pm
Much as I love constant pressure clips, on my recent visit to Adrian at Japandirect to get work done, he had to resort to a jubilee clip to stem a drip on mine in exactly the same place. Oh the shame of it!
Post by Simon Jones » Fri Oct 24, 2014 7:36 am
If you've got a problematic joint apply some gasket compound such as Blue Hylomar: http://hylomar.com/hylomar-product-rang ... compounds/
It's non setting so forms a reliable seal and the pipe can easily be removed without any damage. I've used Jubilee / worm drive clips on many different cars without any problems, but where there is a plastic connection such as the radiator, you're better off applying sealant rather than tightening the clamp so much that it damages the plastic.
As a thought, it's not the plastic drain plug that's leaking is it?
bongobridge
Post by bongobridge » Fri Oct 24, 2014 8:23 am
Hi thanks for the replies it is the metal tube on the bottom thinking it may be damaged ? I read that jubilee clips aren't suitable as the don't seal in a perfect circle ?? Going try the type with the bolt to see if they work better ?
Nick & Jen
Post by mikeonb4c » Fri Oct 24, 2014 8:27 am
bongobridge wrote:Hi thanks for the replies it is the metal tube on the bottom thinking it may be damaged ? I read that jubilee clips aren't suitable as the don't seal in a perfect circle ?? Going try the type with the bolt to see if they work better ?
I think you have to try it and see. It's done job on mine. Simon's sealant suggestion ought surely to settle it, though that would probably mean draining and dismantling, which is tedious.
Post by haydn callow » Fri Oct 24, 2014 8:56 am
Try fitting a second jub clip!!
Post by rita » Fri Oct 24, 2014 10:40 am
" Jubilee Clips" don't leak, the hose and or the connecting pipe do, and sometimes need replaced/repaired/cleaned.
Gasy
Post by Gasy » Fri Oct 24, 2014 3:31 pm
Get the right size jubilee clip for the job and they are better than constant pressure clips
In my op
I think the only reason constant pressure clips are fitted in the factory's
Is to eliminate human error
( a clip not done up enough or to much )
Post by Simon Jones » Fri Oct 24, 2014 5:38 pm
It's plastic, hence my comments about using sealant & not over-tightening :)
Post by Northern Bongolow » Fri Oct 24, 2014 6:41 pm
if you tighten a jubilee clip up tight it can crack the plastic stub.
i know its a bummer to check but it may have done this already.
Post by teenmal » Fri Oct 24, 2014 8:22 pm
Its possible that the vehicle could be fitted with a radiator of all metal construction .
Post by Simon Jones » Fri Oct 24, 2014 10:25 pm
It is possible although it would probably have to be a custom made one. Mazda rads have plastic end caps and the generic ones widely available use the same construction.
Post by haydn callow » Sat Oct 25, 2014 12:33 am
Gasy wrote:Get the right size jubilee clip for the job and they are better than constant pressure clips
In my op
The constant pressure clips I am on about are the NORMA type...they do work very well
