NEW REAR SHOCKS
ELZE
NEW REAR SHOCKS
Post by ELZE » Sat Feb 28, 2015 7:56 pm
I was thinking of having a tow bar fitted now I have had the LPG conversion done. also thought it a good idea renew the shocks front and rear (beefing up the rear with spring booster if poss) The new gas tank underneath is extra weight and the fact I may be towing a boat/caravan.
Problem is I cannot find what I need in the members shop i.e. shocks and spring boosters, or fleabay???
any ideas please guys and gals ?
philpdr
Re: NEW REAR SHOCKS
Post by philpdr » Sat Feb 28, 2015 8:10 pm
Shocks and springs here,
http://www.mazdabongo.com/
maybe a phone call about boosters?
ELZE
Re: NEW REAR SHOCKS
Post by ELZE » Sat Feb 28, 2015 8:17 pm
Thanks muchly, Obviously looking in the wrong place :roll:
Any discount for members?
Also where can I get door rubbers?
Re: NEW REAR SHOCKS
Post by Northern Bongolow » Sat Feb 28, 2015 9:58 pm
mazda can order the harder to get stuff, or second hand should be ok if the od ones are just damaged.
http://www.bongospares.co.uk/
Re: NEW REAR SHOCKS
Post by Simon Jones » Sun Mar 01, 2015 12:33 am
One of my rear shocks was leaking so I bought these for £110 which includes a set of filters: http://www.ebay.co.uk/itm/MAZDA-BONGO-1 ... 58bfcaadd5
These are the spring assistors to use: http://air-lift.co.uk/product.php?unique_id=341
You'll need a pair of spring compressors to get the springs out and then spread the coils to slide the bags in. I've got LPG, a rear conversion and sometimes fit a Thule Backup box on the towbar and they help give it a bit of a boost.
Ideally you'd have towbar fitted before the LPG tank otherwise it may now have to be moved / removed and refitted to squeeze the towbar in.
ELZE
Re: NEW REAR SHOCKS
Post by ELZE » Sun Mar 01, 2015 11:35 am
Simon Jones wrote:One of my rear shocks was leaking so I bought these for £110 which includes a set of filters: http://www.ebay.co.uk/itm/MAZDA-BONGO-1 ... 58bfcaadd5
Thanks for this good information, just what I was looking for as I knew someone must have done this before somewhere.
I will give these a looking at. looking on the bongo shop it will cost almost £400 just for the 4 shocks. God knows what springs would cost?
The guys who did the LPG conversion are doing the tow bar so no worries there then! I have spring clamps/spreaders/ramps/axle stands etc from my old Landover days.
Is should not be a difficult job just time consuming and fiddley I expect. Blood, skin and knuckles I call it!
As for the door rubbers I will ask Mazda as I never thought of that strangely enough, probably because they charge so much.
Thanks again Simon.
ELZE
Re: NEW REAR SHOCKS
Post by ELZE » Sun Mar 01, 2015 11:58 am
Hi Simon
Tried to purchase these but when I went to CART there was no button to checkout? it is just me?
I managed to order the shocks :roll:
wonkanoby
Re: NEW REAR SHOCKS
Post by wonkanoby » Sun Mar 01, 2015 1:13 pm
no it seems they need to sort out their site
ELZE
Re: NEW REAR SHOCKS
Post by ELZE » Sun Mar 01, 2015 1:20 pm
Thank god for that i thought i was having one senior moment too many
Re: NEW REAR SHOCKS
Post by Simon Jones » Sun Mar 01, 2015 3:11 pm
There is another supplier of the same make kit and they did used to list them on eBay. Probably will ping up with a bit of Googling.
samuel
Re: NEW REAR SHOCKS
Post by samuel » Sun Mar 01, 2015 3:41 pm
What a clean and smart Bongo Simon. A credit to you sir.
I'm not sure what they're called but I'm after the piece behind the brake disc. I guess its a protective plate for the disc and pads. I need them for both front and back.
Any idea where I can source these?
Tim
"Living the Dream"
helen&tony
Re: NEW REAR SHOCKS
Post by helen&tony » Sun Mar 01, 2015 5:14 pm
Here you go:
http://www.mattsavage.co.uk/acatalog/co ... lpers.html
That's where I got mine. They are very helpful, but make sure you get the right kit. There's one for lowered Bongos, and one for standard
ELZE
Re: NEW REAR SHOCKS
Post by ELZE » Mon Mar 02, 2015 10:30 am
helen&tony wrote:Hi
Here you go:
The one listed is for a Bongo with lowered suspension? I will give them a call.
thx
ELZE
Re: NEW REAR SHOCKS
Post by ELZE » Mon Mar 02, 2015 10:38 am
wonkanoby wrote:no it seems they need to sort out their site
I sent them an email this morning, was going to ring them but the web says that they may not always be able to answer :roll: :roll:
Why is it so difficult to get what you want these days? You can have any old crap you don't want in a jiffy but try getting something you need in a hurry in nigh impossible.
ELZE
Re: NEW REAR SHOCKS
Post by ELZE » Mon Mar 02, 2015 10:40 am
samuel wrote:What a clean and smart Bongo Simon. A credit to you sir.
Tim
I agree it's something to aspire to!
Perhaps when I am retired fully and not ploughing through farms to build wind turbines, I can turn my hand to keeping Bongy pristine [-o<
