Rear fog light wiring
How do I wire up a fog ? Any probs to look out for? Best route for cable?
No advice forthcoming so -
Flush fit fog lamp cut into bumper .Took two core 14amp wire from fog under bumper - up through rear light wiring harness grommet -along the back of the plastic panels ( having removed cubby and aircon panel for access ) - tucked under edge of trim at drivers door -under dash to RHS of steering wheel . Used a Mazda MX5 mk1 illuminating fog switch ( same as this but ?2.00 from scrappy - http://www.mx5parts.co.uk/product_info. ... cts_id/129 )
this matches the lower bank of switches . In line 7amp spade fuse.
I am clueless when it comes to electrics so a mate is connecting it up for me on Sunday
- dandywarhol
Oops ,sorry Dandy - credit where credit is due - I spoke to D on the phone and he told me about the rear light cluster removal and possible cable route- made the job easy peasy ( take out two external screws and gently /carefully push the whole cluster to the right to release from holding lugs ).
What I meant was that nothing appeared on the site. I was hoping for detais of wiring connections.
Anyway , now that the information is posted i hope that it may benefit others .
I will not be able to pass on info on the actual connections 'cos I am the class dunce on electrics even though it is apparently simple stuff.
BTW I rang a garage in Stirling which specialises in imports ( the one in the members section which does waxoyling ) and they quoted me silly money to install a rear foglight on an import - they said that it takes ages to run the cable
Mark & Shelly
Lots of rear fogs seem to be wired into that front fog switch block ,as are mine. But I have converted it to a connection via a relay, as it would be when used for a front fog.
I might be wrong as I am no expert in vehicle electrics, but with a direct connection onto that wiring you are running everything through the same fuse, and if you have a problem with the fog you will lose the side / tail /& dash lights as well which can't be a good thing if it is foggy.
trevd01
I used a flush fit fog mounted in the bumper. I altered the housing - filled in the Land R screw mount holes /painted it satin black / used black silicone to glue it into place. looks very 'factory ' and glows bright red on the bumper -nice'n'safe . I might spray the housing the same colour as the bumper later if I can get a spray can to match the colour.
I do not like non - factory switches . There are loads of blanks on the dash so why spoil the job for a hape'worth? .It would apparently be easy to buy the proper Mazda switch and transfer the wiring if you know a little about electrics
trevd01
