F/R Parking sensors
tcflinty
F/R Parking sensors
Post by tcflinty » Wed Apr 01, 2015 2:06 pm
I have F/R Parking sensors , the problem I have is the bleeping has stopped . It still shows me on the dash how far I am from obstacles . Is there a different fuse for the bleeb ?
No, this isnt a wind up, on this special day for pulling pranks. :lol:
Flinty the paragliding Bongolier
Re: F/R Parking sensors
Post by g8dhe » Wed Apr 01, 2015 2:16 pm
Its only a single fuse, are all the other bleeps working OK form the warning system ?;
tcflinty
Post by tcflinty » Wed Apr 01, 2015 2:24 pm
Thanks Geoff I will report back asap .
Flinty
tcflinty
Post by tcflinty » Wed Apr 01, 2015 3:15 pm
Geoff I have checked all the fuses under the dash and they are all intact , all other relavant bleeps ie when you turn ignition oo ect, work ok.
Still no bleeps from parking censor . :?:
Flinty
Post by Bob » Wed Apr 01, 2015 6:39 pm
I'm guessing this is an after market fit, so you could have a line fuse fitted anywhere. :?
Can you follow the wires from either end?
tcflinty
Post by tcflinty » Wed Apr 01, 2015 7:42 pm
Dont quote me but I think they were factory fitted on some Bongo's you have one sensor on the driivers side front bumper and four sensors on the rear. I have seen quite a few around.
Someone out there must know were my bleep as gone .
Flinty
Tony x
Post by Tony x » Wed Apr 01, 2015 8:18 pm
Check the settings menu - on ours, the press of a button turns the sensors onto silent mode.
Be nice if this is the solution for you...
tcflinty
Post by tcflinty » Wed Apr 01, 2015 8:31 pm
Sorry Tony not the solution tried that , if you press the button it also turns the display off . The display all works fine it tells you the distace you are away from obstacles just no bleeeeeeeep . !!!
Regards Flinty
Post by Simon Jones » Wed Apr 01, 2015 9:23 pm
This is the f/f system towards the bottom of this page:
It would also have one of these at he front and rear:
tcflinty
Post by tcflinty » Wed Apr 01, 2015 10:21 pm
Thats the one Simon =D> , any ideas on how to get the sound back . You were my big hope .
Flinty
Post by Simon Jones » Wed Apr 01, 2015 10:31 pm
No, sorry: mine are aftermarket although fitted in Japan. Geoff (g8dhe) is you're best bet as he's got them and is a whizz with electrickery :).
Post by g8dhe » Wed Apr 01, 2015 10:36 pm
Had anything been done just before the bleeping stopped ?
Thinking about it it doesn't appear to be connected to the rest of the Bongos SWS, but nor does it appear to have any holes in the displays for a bleeper to emit a sound from on ours I'll have a closer look tomorrow!
I assume you don't get any error message on the display when it first turns on and does it self check ?
tcflinty
Post by tcflinty » Thu Apr 02, 2015 8:48 am
Hi Geoff , DONT get any messages on the dash but to answer your first question Yes I had done something out of the ordinary . My battery went flat so I jump started it .THEN NO BLEEPS. SO has the surge done a relay in or not .
Flinty
Post by g8dhe » Thu Apr 02, 2015 10:00 am
Ah, right. Anyway checked mine and yes the sounder for the bleep seems to be internal to the display module, rather than from the rest of the SWS.
So whatever has caused the problem, and a jump start sounds a possibility, your going to have to take a look at or replace at worst the front display.
I think its held in place by the usual spring clips, but never had to remove mine and its reluctant to come out as I just gave it a push/pull in all directions, but has the feel of being springs holding it in place.
See here http://lushprojects.com/bongopartsmk2/c ... 2of03.html
it looks like 4 springs on the underneath, certainly no fixing bolts/nuts shown!
I don't have the circuit for the unit, otherwise I would have put it up on the wiring diagrams, and I can't remember anyone reporting a fault before, so looks like your a first!
tcflinty
Post by tcflinty » Thu Apr 02, 2015 11:13 am
Its Back !!!!!!! =D> =D> =D>
What did I do ' NOTHING ' its a BONGO and they do these type of things . :!: I did stand in front of it starring for a long time. !!
I think some how the system rebooted itself and its up and running again .
So to all those who replied may I just say a big thank you .
Flinty The Paragliding Bongalier
