I've got the JAL mushroom roof, which opens from the passenger door side, and I'd like to get a Fiamma 45s awning.
Does anyone have any experience with this combination - or a similar one?
When travelling solo, I won't be able to lift the roof from the centre as usual, but I've been experimenting and I can lift it with a pole from the rear corner, and then the gas struts do the rest.
Tucking the vinyl back under the closing roof might be a bit fiddly, as I'll have to reach over the awning casing, but it looks doable.
But I'd welcome some advice before I shell out £500 or so!
Thanks in advance.
Fiamma awning with side lifting roof
Moderator: Muzorewa
keridavies
- Junior Bongonaut
Re: Fiamma awning with side lifting roof
Yes, we had exactly that.
I definitely wouldn't advise lifting the roof from one corner as it will twist and sooner or later it will break something.
After a lot of faffing about trying different things we just pushed it up from inside, not easy but quite possible. I then fastened a webbing loop onto the inside of the roof using the bolts that hold the outside eye in place. You can then carefully pull the roof down and take the weight as it comes down.
Hope this helps.
Hope this helps.
keridavies
- Junior Bongonaut
From the inside - of course! I've just tried it and it worked perfectly.
What a great tip - many thanks.
