Central Locking Slow
Mark Elvin
Post by Mark Elvin » Sun May 31, 2015 8:21 am
My central locking is becoming slow. When I unlock using either remote or the key in the door the other doors are sometimes quite slow to unlock, can take 10second or so on occasion.
My initial thought is that the central locking relay is slow as I know it's not related to low battery voltage as both batteries are good.
anybody else had a similar fault?
Re: Central Locking Slow
Post by Simon Jones » Sun May 31, 2015 9:24 am
Do you know if it's factory fitted or aftermarket? Majority of vehicles of your vintage have central locking controlled by the drivers side lock but it's unusual to find one with remote central locking. As the problem occurs with the key as well as the fob, it sounds like the problem may be with switch/actuator in the drivers door.
Mark Elvin
Post by Mark Elvin » Sun May 31, 2015 9:26 am
It's factory fitted central locking with aftermarket alarm that operates all doors. It was slow before the alarm was fitted.
jimmo62
Post by jimmo62 » Sun May 31, 2015 9:37 am
I would guess dirty/sticky contacts in the Driver's door lock is taking a while to make the circuit which tells the control unit to activate the rest of the locks. Not sure how accessible the contacts are, may be worth giving it a good dose of switch cleaner?
Post by mikeonb4c » Sun May 31, 2015 9:47 am
Is your starter battery in good condition?
Mark Elvin
Post by Mark Elvin » Sun May 31, 2015 10:24 am
Mark Elvin wrote: My initial thought is that the central locking relay is slow as I know it's not related to low battery voltage as both batteries are good.
Post by Simon Jones » Sun May 31, 2015 10:42 am
Any other symptoms such as slow electric windows? That might point to something like a dodgy earth to the drivers door.
Mark Elvin
Post by Mark Elvin » Sun May 31, 2015 4:20 pm
Nope. Just the central locking.
Post by g8dhe » Sun May 31, 2015 4:31 pm
Is the delay constant or does it vary between operations ? If it varies I would suspect the contacts, but if its always constant it could be the control module which is a very simple bi-stable switch circuit driving the relay for the pulse required. Click the Orange box for the actual circuit details;
Post by mikeonb4c » Sun May 31, 2015 4:50 pm
Apologies, should have read your post more carefully #-o
Mark Elvin
Post by Mark Elvin » Sun May 31, 2015 4:56 pm
g8dhe wrote:Is the delay constant or does it vary between operations ? If it varies I would suspect the contacts, but if its always constant it could be the control module which is a very simple bi-stable switch circuit driving the relay for the pulse required. Click the Orange box for the actual circuit details;
it varies. I'll try to clean the contacts
