haydon coolant alarm chirping
steveandmary
- Bongonaut
hi alarm chirps on and of when it wants had mine 3 years now . coolant level fine recently bled system a few months ago .
having problems , contacting Haydn . any ideas please love this alarm hope i dont have to replace . thanks all
- Simon Jones
Re: haydon coolant alarm chirping
Have you got red or green/blue coolant? Red coolant can do this as it coats the screw with a protective layer.
When was coolant last changed? A really weak mix can cause problems.
Are you experiencing any charging issues (battery & sediment lights glowing on the instrument panel?). The alarm is very voltage sensitive so a fault with the alternator can cause erroneous readings.
steveandmary
- Bongonaut
red coolant no electric problems .
clean the little screw
steveandmary
- Bongonaut
wonkanoby thanks for tip will do.
He's good just ask for a screw and he will sort you out
Maybe it's just me but that just sounds very wrongGasy wrote:He's good just ask for a screw and he will sort you out
www.bongodecals.com
Manufacturer of quality replacement decals for Mazda Bongo's and Ford Freda's
Andyf wrote:Maybe it's just me but that just sounds very wrongGasy wrote:He's good just ask for a screw and he will sort you out
He is always willing to oblige.
- mellon man
HANG ON have I clicked on the wrong site
