We have a problem with our interior light (middle light- long tube style bulb), we thought it was just the bulb that needed replacing but we have done this and it is still not working, please can anyone offer advice (real pain using the torch!!!) Thanks!
Interior light not working?
Hello Bongo Techies!
Home is where you park it.....
Re: Interior light not working?
Other interior lights work? Assuming "yes", then contacts on light's circuit board fail. This fact sheet explains http://www.igmaynard.co.uk/bongo/member ... lights.pdf
Chris with BertieB
Bah! Just tried to access this factsheet and found that our password is out of date!!! Someone (Hubby) has let our membership lapse me thinks!!!
Hello,
Just swapped mine for an led module, so I have the tube and pcb spare if you need it.
02-07-1999 TinTop 2WD Oil Guzzler with Hyper Seat
Think the pass word is changed monthly or so
You probaly have a old password
Someone will be along soon to help
Lots have replaced bulb for LED lights
Do a search there is some chats about LED lights
Put and inbetween eg led and light
Just checking if it works in either of the two "on" positions, as I had an earth fault with mine at the plunger switch on the sliding door stopping mine from activating when the door was opened.
Took the switch off and cleaned it up and that sorted mine.
www.bongodecals.com
Manufacturer of quality replacement decals for Mazda Bongo's and Ford Freda's
I had this some weeks ago. See if the metal contacts that hold the tube are loose. If they are just take the thing apart and resolder them to the pcb.
1995 2.5 TD
I'm sure the password hasn't changed this month.....
I think the reason given was ' because I can't be arsed'
Paul
Today is a good day - tomorrow will be better
