Hello everyone; Gearbox whine
peeky1323
Post by peeky1323 » Sat Dec 12, 2015 6:24 pm
Hi everyone,
I became the happy owner of a 1998 Bongo with AVA side conversion today. While driving it the 150 miles home I noticed quite a loud whine from what I am presuming is the gearbox at around 55 and above. It only happened it top gear, and if I lift off the accelerator it goes, but then comes back when I put the power back on. It quite high pitched. Does anyone think this is the sign of much trouble ahead or just a fluid change or something easy... please please please say it not too bad... Van has done 70k Miles
Will post some pictures tomorrow :-)
Thanks,
Matt
cmm303
Re: Hello everyone; Gearbox whine
Post by cmm303 » Sat Dec 12, 2015 6:58 pm
Welcone to the forum. What a shame to hear "noises" on your first bongo journey. Fingers crossed for you.
2WD or 4WD, auto or manual? Assuming auto, Does the gearbox change up and down smoothly? Is the ATF a "clean" translucent red/pink? Murky brown suggests it's due a change anyway, but not sure if that would solve the whine.
Not happening in 3rd does eliminate the diff.
Chris with BertieB
peeky1323
Post by peeky1323 » Sat Dec 12, 2015 7:09 pm
thanks for the reply. sorry should have said 2WD 2.5D auto. haven't looked at fliud yet, will do tomorrow in daylight. It changes up and down just fine.
Post by teenmal » Sun Dec 13, 2015 1:13 pm
Hi peeky,it could be loads of faults causing this, the first thing that I would check is the manifolds for broken studs or gaskets.
Post by g8dhe » Sun Dec 13, 2015 1:40 pm
This is the exhaust manifold bolt that shears most often;
Post by mikeonb4c » Sun Dec 13, 2015 1:59 pm
Mine developed something like this. Very faint, high pitched, and only at certain speeds and where gearbox under load. I'm certain it's the gearbox. But it happened nearly 4 years ago and gearbox has continued to work perfectly and, if anything, the noise has lessened. I don't woody about it, and passengers can't hear it as its position specific. If gearbox went, I'm advised 2nd hand + fitting would be around £500. Mine had autofliud change 6 years ago.
Post by teenmal » Sun Dec 13, 2015 2:14 pm
mikeonb4c wrote:Mine developed something like this. Very faint, high pitched, and only at certain speeds and where gearbox under load. I'm certain it's the gearbox. But it happened nearly 4 years ago and gearbox has continued to work perfectly and, if anything, the noise has lessened. I don't woody about it, and passengers can't hear it as its position specific. If gearbox went, I'm advised 2nd hand + fitting would be around £500. Mine had autofliud change 6 years ago.
I can remember your reported problem then.
Quote
"The slight whine only seems to be when moving off and when cold "
Post by mikeonb4c » Sun Dec 13, 2015 3:36 pm
Quote
Did I really write that? That's totally not what it's like so I must have been having a brain fart. :shock: :lol:
Post by mikeonb4c » Sun Dec 13, 2015 3:42 pm
Quote
Just found the original thread. Apologies it was less than 3 years ago doh!
http://igmaynard.co.uk/bongo/forum/view ... ed#p607920
peeky1323
Post by peeky1323 » Sun Dec 13, 2015 8:31 pm
thank everyone, I will check the bolts tomorrow. Fluid looks correct colour. It is quit loud at 60mph and above. Passengers have all commented "what's that noise".
Does anyone know roughly what the cost would be to get it fixed if this is the case... and even better can anyone recommend a Bongo friendly garage in mid Devon I could take it to to get it checked out? I am equal distance between Barnstaple and Exeter.
Post by mikeonb4c » Sun Dec 13, 2015 9:54 pm
peeky1323 wrote:thank everyone, I will check the bolts tomorrow. Fluid looks correct colour. It is quit loud at 60mph and above. Passengers have all commented "what's that noise".
Allans in Plymouth are legendary if that is not too far off.
Bluespanner
Post by Bluespanner » Mon Dec 14, 2015 9:08 pm
It might be worth checking the power steering fluid level under the drivers seat. I posted on here a while back with waht i thought was gearbox/tramisson problem, an unusal whine. It turned out i had a leak in the seals and the power steering fluid was leaking and the power steering fluid tank was almost empty. I topped it up with a ps fluid that had a leak fixer element and to my amazement the whine dissappeared.
Bluespanner
Post by Bluespanner » Mon Dec 14, 2015 9:16 pm
Hopefully the link to the thread will copy ok
It might help to rule out one the possibles
http://igmaynard.co.uk/bongo/forum/view ... =3&t=63127
peeky1323
Post by peeky1323 » Tue Dec 15, 2015 2:49 pm
thank guys. I will go check all mentioned as soon as it stops raining sideways down here in Sunny Devon!
I plan to change ATF, and Diff oil soon anyway.
peeky1323
Post by peeky1323 » Tue Dec 15, 2015 6:31 pm
OK I have managed to have a look.
g8dhe, it looks like I have a sheared bolt just like in your picture. Is this a big job? I think I will call Allans in Plymouth. It's an hour and a half from me but I want the van checked over and the manifold bolt done..... and all the other things he finds that I can't do.
I also noticed an oil leak on the rover cover under the drivers seat. I checked the engine oil and it was over full. It wasn't when I first looked at the van before I bought it. Hope this hasn't shafted something else. I will drain a bit off tomorrow. Why are people so stupid?
ATF fluid looks redish and smells like oil not toast.
Power steering fluid level is fine.
Not sure how to check the Diff oil. Can anyone let me know how to do this?
Many thanks
I was to change engine oil, Diff oil, ATF oil very soon but I have a 300 round trip journey on Thursday so I will just drain a bit off for now.
