V6 Cambelt any other business?
wildrobot
Post by wildrobot » Tue May 03, 2016 11:30 am
Hello so i'm getting the Cambelt on my V6 done. I've had varying quotes (all from Bongo specialists) from "Sorry i won't do that job to £580"!
The best quote i've had so far is £263 including VAT in Bristol which isn't far from me
I just wondered though is it worth having anything else done at the same time? i've seen seals mentioned on other threads.
Many thanks
Re: V6 Cambelt any other business?
Post by g8dhe » Tue May 03, 2016 12:46 pm
Yes the cam oil seals whilst they are at the front of the engine! Normal price for a V6 cam belt and oil seals is £400-£600 depends mainly on manhour costs rather than parts as its a pig to get too!
Post by teenmal » Tue May 03, 2016 12:54 pm
As Geoff has said, plus get the mechanic to test the tensioners in particular the "Hydraulic Tensioner" also the water pump for bearing wear or signs of seepage, and drive belts.
wildrobot
Post by wildrobot » Tue May 03, 2016 1:38 pm
Ok thankyou for your suggestions
So rather than just getting them to fit a water pump check it out first, that makes sense
windywatson
Post by windywatson » Fri May 06, 2016 11:30 pm
Depending on how long your intending to own the van. If you're going to have the van for a number of years and want trouble free motoring then have all of the front end of the engine done. As said it's a pig of a job and labour makes up a big part of the bill. So have the cam and crank oil seals done as they will leak at some time in the life of the engine. Also have the cambelt tensioners replaced as well, you can get a cam belt kit that comes with a set of the required ones. Yes get the water pump done to as this will the only time it will be cheap to have done during the belt change.
also get the garage to check all of the auxiliary belt tensioners as mine where getting past it with noisy bearings. Makes it a bigger expense but well worth it.
Windy-Watson
2001 V6 Tin Top
