Key numbers from VIN numbers and key numbers on the door lock mechanisms
Purple Pixie
Post by Purple Pixie » Wed May 18, 2016 1:45 pm
#1 any way to order a replacement key (non-transponder) from the chassis number alone?
#2 I believe the key number is on the lock mechanism, where?
I have access to an endoscope used to access cavities in houses,
what am I looking for and where, if I get access to inside the door
by pulling away a trim panel?
Many thanks! This is for a nice lady with 2 worn out after market
keys the previous owner sourced
DrB 8)
1999 Ford Freda - "Purple Pixie"
Re: Key numbers from VIN numbers and key numbers on the door lock mechanisms
Post by Ian » Wed May 18, 2016 2:09 pm
Purple Pixie wrote: #1 any way to order a replacement key (non-transponder) from the chassis number alone?
Not possible I'm afraid due to security reasons
nth
Post by nth » Wed May 18, 2016 6:02 pm
Is that just a Mazda thing then ? plenty of other manufacturers have a key number database from the VIN & can order you a pre cut key if you go in with the V5 & I.D. etc assuming you have the original locks of course.
95 2.5d 4WD AFT
Post by Ian » Wed May 18, 2016 10:05 pm
Mazda UK will not supply keys based on Mazda Japan database of VINs. I was told it was a security issue.
Bongoplod
Post by Bongoplod » Wed May 18, 2016 11:05 pm
Purple Pixie wrote:Hi
DrB 8)
Dr B.....
My key snapped in half in the ign barrel
Wheelquick came out,dismantled the ign and i took it to a locksmith who made me a key.
So I think the key number may be somewhere on the ign barreL
Brian
Post by teenmal » Wed May 18, 2016 11:22 pm
The number should be stamped on the lock/ignition barrel , the easiest one to use would probably be the drivers door, presuming the door locks and Ign use the same key.
Purple Pixie
Post by Purple Pixie » Thu May 19, 2016 8:08 am
Can the stamped number be seen on the lock by looking inside the door somehow?
nth
Post by nth » Thu May 19, 2016 6:26 pm
Bongoplod wrote: Dr B.....
Brian
I don't think key numbers have been stamped on door locks since Ford Sierras !
Most likely the garage stripped the lock to retrieve the broken bit & taken both parts to a key cutters, done it many times, as long as you have all the parts of a broken key most key cutters can copy it.
95 2.5d 4WD AFT
Purple Pixie
Post by Purple Pixie » Thu May 19, 2016 6:40 pm
I am going to stick an endoscope into the door space once I can find out where the number is marked on.....! :?:
Post by teenmal » Thu May 19, 2016 7:32 pm
I don't think you will be able to read the code without taking the lock out and then removing the barrel , this should give you an idea of what is involved.
http://www.triple-c.com/How_to_find_you ... y_code.cfm
Purple Pixie
Post by Purple Pixie » Fri May 20, 2016 8:08 am
teenmal wrote:I don't think you will be able to read the code without taking the lock out and then removing the barrel , this should give you an idea of what is involved.
http://www.miata.net/garage/lock_core.html likewise? will check
JB
Aarebb
Post by Aarebb » Fri May 19, 2017 12:22 pm
I replaced my car lock a few days ago, so I now feel more safe and secure as I know that it will prevent the chances of theft in my absence.
Purple Pixie
Post by Purple Pixie » Fri May 19, 2017 12:28 pm
Think about getting a Disklok for that added security assuming it has an alarm and an immobiliser
http://www.disklokuk.co.uk/?gclid=CjwKE ... oCcPzw_wcB
20 mins of hammering or a disc-cutter! https://youtu.be/KlBYDB2OA28
TiJ4
Post by TiJ4 » Wed Dec 04, 2019 2:40 pm
It is not easy for a common man to open a door lock without having a key, unless he has the technical knowledge about locksmithing. However, I would recommend all my friends to hire an experienced locksmith for quick assistance.
Flanners
Post by Flanners » Fri Dec 13, 2019 9:31 am
The near do wells appear to do quite well with a screwdriver or punch.
