Due to the kids getting a little excited in jumping over Fiamma table etc, that led to the floor support's grub screws coming out of the holes, I think I'm in need of purchasing a Fiamma tripod table support. I now have a small pee hole straight thru to the road! Could come in use with the kids tho......
Has anyone used one of these supports before? Sturdy enough? £35 bucks on the web..... Otherwise I may be thinking of possibly bolting the Fiamma hole support back thru the floor with a back plate support underneath?
Or open to an other ideas..... Get rid of table?
Many thanks
Fiamma tripod table support any good?
- Muzorewa
Re: Fiamma tripod table support any good?
Both. We've trashed our floor socket (and renewed it) and got one of the tripods, both are excellent in the right situation
Many thanks for your reply, did you fix the support yourself? Bolted thru the floor? Or just used new grub screws? I think I'm gonna have to take it to the garage as I don't think I'd be able to fit under the van to tighten bolts........
Regards
Regards
- Muzorewa
On ours it screws into the plywood floor from above so an easy DIY job.
I bought a tripod as it then allows me to use the table outside on a good day. Not used it yet though.
