				Oil leak?
				Posted: Tue Sep 20, 2016 7:23 pm
				by 2newbies
				hi all,
crawling under daisy today i noticed that some oil had sprayed up underneath, just in front of the spare wheel.  does anyone have any ideas where this could be coming from - could it be from a drive shaft seal?
any ideas much appreciated.
thanks
Paul
				Re: Oil leak?
				Posted: Tue Sep 20, 2016 9:51 pm
				by Northern Bongolow
				is it 2 wheel drive or 4 wheel drive, one of them, and not the other has a grease nipple in the universal joint on the prop, this can fling out and look a bit messy.
or it could be the nose seal on the diff, check the oil level, and check that the little thimble breather is clear, these can rust shut, its on the top of the diff, it should turn/spin freely and lift and fall slightly.
http://lushprojects.com/bongopartsmk2/c ... mgno=.html.
this looks like a limited slip mechanism diff.
				Re: Oil leak?
				Posted: Wed Sep 21, 2016 6:47 am
				As a general rule you need to degrease the affected area to help establish the origin. But you will know that, so i'll fetch me coat and be off!
				Re: Oil leak?
				Posted: Wed Sep 21, 2016 10:58 am
				by Diplomat
				Oil from the usual leak at the upper offside front of the engine and diesel leaking from the fuel pump can easily end up deposited in the area you are talking about. In worse cases it can end up eddying up onto the tailgate.
Providing it doesn't drip onto the road or driveways it can offer a degree of rust protection just where road salt gets a hold.
Frank
				Re: Oil leak?
				Posted: Wed Sep 21, 2016 12:03 pm
				by Merlot man
				Diplomat wrote:Oil from the usual leak at the upper offside front of the engine and diesel leaking from the fuel pump can easily end up deposited in the area you are talking about. In worse cases it can end up eddying up onto the tailgate.
Frank
I know that these buses are great but now they even come with a self rust proofing feature !   I like it
Brian
