Huh? Magic Oil?
SteveM
Huh? Magic Oil?
Post by SteveM » Thu Oct 27, 2016 9:53 am
One for the Bongo sleuths.....
Made a 600 mile round trip at the weekend, motor running like a dream (2.5 petrol with lpg), on the morning before we headed up she flew threw the mot. Tester advised that it looked like we had a small oil leak from somewhere.
On our return, we had a phone call to say that we had left an oil patch on the drive we had been parked up on. Cue a hurried oil level check in the dark on a slight slope ( nose up). Level is below the minimum.
So due to head north again yesterday and just before leaving put the van on the level checked water, ok, then filled up the oil, it took 2 litres. Drove to garage to fill up with gas, approximately 8 miles. Filled up then noticed a steady drip under the van, oil. Checked it there on the level and it level is now halfway between max and min. Abandoned the trip, returned home, check the oil and it's under minimum.
Put some cardboard underneath overnight and there is a small patch on it this morning. Have pulled the van off the drive this morning, checked the level and it's back up to the max line!! I haven't added any oil, so I'm scratching my head a bit.
Any ideas?
Thanks oil
Re: Huh? Magic Oil?
Post by Bob » Thu Oct 27, 2016 10:41 am
Did you let it sit for 10/15 mins after moving off drive so oil coould drop to lowest point?
Is the oil still 'Clean', ie not contaminated with fuel or coolant?
SteveM
Re: Huh? Magic Oil?
Post by SteveM » Thu Oct 27, 2016 11:07 am
Hi Bob,
No didn't wait after moving off the drive. But did recheck 20 minutes later and it was at the max level.
I have just run the engine for 10 minutes and the drip has re-appeared, the oil is clean, nothing mixed in with it. Have just taken it to a local garage who are going to take a look to see what's going on under there
SteveM
Re: Huh? Magic Oil?
Post by SteveM » Thu Oct 27, 2016 2:15 pm
Garage reckons the leak is coming from behind the timing belt covers. Are the cam shaft oil seals back there? Only had new ones fitted approx 1500 miles ago
Re: Huh? Magic Oil?
Post by Ian » Thu Oct 27, 2016 2:34 pm
Check out this thread from about 6 years ago: http://igmaynard.co.uk/bongo/forum/view ... ne#p402289
SteveM
Re: Huh? Magic Oil?
Post by SteveM » Thu Oct 27, 2016 4:56 pm
Thanks for the info
SteveM
Re: Huh? Magic Oil?
Post by SteveM » Sat Nov 05, 2016 7:34 am
Crank shaft oil seal was the culprit. I was probably being a dipstick with the dipstick.
Gasy
Re: Huh? Magic Oil?
Post by Gasy » Sat Nov 05, 2016 8:12 am
At least you found it now
And thanks for reporting back
Re: Huh? Magic Oil?
Post by Bob » Sat Nov 05, 2016 9:26 am
Yes, thanks.
Letting us know what the problem was is a big help for others in the future. =D>
Bongolia
Re: Huh? Magic Oil?
Post by Bongolia » Sat Nov 05, 2016 6:36 pm
Bob wrote:Yes, thanks.
Second that.
