I've had a search but haven't been able to find an existing supplier of leisure battery wiring looms.
I've just bought a Bongo which has had a full conversion, but the blinds and radio still run off the vehicle battery which is really quite annoying.
Any help much appreciated.
Thanks,
Pete
Leisure Battery Wiring Loom
- Bongonaut
Re: Leisure Battery Wiring Loom
You should be able to contact "Rooster" here , he is a moderator, he makes excellent kits.
http://www.bongoforum.me.uk/
Good Luck.
Good Luck.
- Bongonaut
Thanks. I saw this come up in a google search and so I did message him last week but he hasn't got back to me yet. I thought he might not be active anymore.rita wrote:You should be able to contact "Rooster" here , he is a moderator, he makes excellent kits.
Good Luck.
You might reach him through ebay also as he sells his kits on there. And i see him popping up on facebook periodically.
- mikeWalsall
Karl does realy good, easy to fit kits for both split charging and the adapter loom, both are simple DIY half hour jobs ..
https://www.facebook.com/RoosterUK
- Bongonaut
Managed to get hold of him on facebook and now have my wiring loom. ThanksmikeWalsall wrote:Karl does realy good, easy to fit kits for both split charging and the adapter loom, both are simple DIY half hour jobs ..
