Hi everyone,
I am a newbie and this is my first post ( of many I am sure).
I recently bought a 2005 Bongo.
When I collected it everything worked fine. I adjusted the electric mirrors to drive home and they worked no problem at all.
On arriving home I parked up and electrically folded in the mirrors, again no problem.
The next day the mirrors went out electrically no problem but the adjustment button did not work.
Can anyone help with this problem please ?
Much appreciated,
Jim.
Electric Mirrors
Re: Electric Mirrors
Hi and welcome
Is both sides not working
You could try some elec cleaning spray on the switch
Someone will be along soon with more info
Hi and thank you for your prompt reply Gasy.
Both are not adjusting but both fld in no problem.
Jim
Jim
Sounds like switch problem then
And you are moving the little switch to either left or right position
Sometimes we are the faulty part
Yes. Moved the switch to select left or right then direction toggle.
Give it some elec cleaner spray
