autoelectrician in South East?
BrightonBongo
Post by BrightonBongo » Mon May 01, 2017 12:19 am
I have a parasitic battery drain on the main vehicle battery which is solved by removing the in-line fuse in the wire from this battery to the zig unit. I can't find a problem with any of the leisure appliances or their fuses. Phil (it's a 2010 JAL Imports full conversion) suspects a fault has developed in the zig unit when I emailed him. Worcestershire is some way from Brighton so I wondered if anyone can recommend an autoelectrician near me who will be understanding and gentle with Bob (2001 2.5 V6 with LPG conversion, mushroom roof and full side conversion)?
Steve
Re: autoelectrician in South East?
Post by Northern Bongolow » Mon May 01, 2017 10:52 pm
doesnt a zig unit have a permanent battery charger in it, if its switched on then a draw test carried out it will show a draw on the circuit.
just trying to save you some money. 8) :wink:
Post by g8dhe » Tue May 02, 2017 4:50 pm
Depends which Zig, CF8/9 are built in Marque 1 is an option and a choice of power supply rating as well.
