I've had been losing water for the last few months (about 1/2 litre a week) which i've been topping up with coolant/water. I eventually tracked this down to a leaking core plug.
When i rectified the coolant leak I had it checked by Fred at discount trucks (sniffer test/pressure test etc) - all fine.
Now it's started losing coolant (about 1/2 litre for every 40 miles) of driving but there's zero evidence of where it goes. I've even put the UV dye in to try and see where it might be leaking from, but it's bone dry underneath. I've had it checked again (sniffer/pressure test) - all good.
So i have two probs:
1. oil entering the cooling system - could it be the oil cooler or head gasket or something else?
2. magically vanishing water
As a side note I've driven the van from the isle of wight all the way up to Edinburgh and back last month without any probs (still had brown goop and losing water).
PS van is 96 2.5TD - had it for 8 years
