aircon valves
dogpausie
aircon valves
Post by dogpausie » Sun Aug 06, 2017 8:26 am
hello all where is the aircon valve for the rear of the van need to get it regassed ,
any recomendations for the birmingham area to get it done ,
thanks
Re: aircon valves
Post by g8dhe » Sun Aug 06, 2017 9:33 am
Its a single system, you fill it from the front by the radiator the fact that it has two cooling matrices is down to the system, but only one compressor drier etc.
Re: aircon valves
Post by rita » Sun Aug 06, 2017 9:39 am
Open the bonnet/hood,remove heater air intake scoop,look down to the Right of the lower bend of the top radiator hoes and you will see a metal pipe with a T .It has a cap with L stamped on it.
The High Pressure connector is in front right hand side of the AC radiator, DO NOT USE THIS CONNECTOR .
950 gas
14ml oil
Good Luck.
dogpausie
Re: aircon valves
Post by dogpausie » Sun Aug 06, 2017 8:55 pm
Thanks supreme being i stand corrected thanks again
