8mm roof bolt sockets pulled out...
Ahead
Post by Ahead » Sat Aug 19, 2017 11:16 am
Whilst unbolting my solar panel from the roof ( to go under the council tip barrier) the 8mm bolts turned with the socket and both sockets came loose in the aft. I can’t seem to get to the underside but think there may have been a corresponding bolt underneath securing the socket? Anyone had this problem? I am considering using 2 part resin to fix the sockets back. Cheers.
Re: 8mm roof bolt sockets pulled out...
Post by mikeonb4c » Sat Aug 19, 2017 7:36 pm
Ahead wrote:Whilst unbolting my solar panel from the roof ( to go under the council tip barrier) the 8mm bolts turned with the socket and both sockets came loose in the aft. I can’t seem to get to the underside but think there may have been a corresponding bolt underneath securing the socket? Anyone had this problem? I am considering using 2 part resin to fix the sockets back. Cheers.
I recall having a similar issue years back and i think i may have resorted to a similar fix, though no liability accepted etc.
Ahead
Post by Ahead » Sun Aug 20, 2017 8:51 am
Thanks Mike, will give the resin a go
phil 1
Post by phil 1 » Sun Aug 20, 2017 9:30 am
Before you go and resin it in have a look at the other 3 fixings as I'm sure that something screws up from the under side of the roof. I had the same problem a long time ago and I'm pretty sure that something had come undone and was found in the roof runner's.
Good luck.
Phil
Post by mikeonb4c » Sun Aug 20, 2017 9:41 am
phil 1 wrote:Hi,
Good luck.
Phil
Absolutely correct and it was a fiddle to find it but i did. And i THINK i then screwed them back together not putting resin on the thread but a little on the seating but i honestly cant remember.
phil 1
Post by phil 1 » Sun Aug 20, 2017 10:06 am
mikeonb4c wrote:
phil 1 wrote:Hi,
Good luck.
Phil
Yep I remember it being a pain to get back in but back in it went and with a bit of sealant not had a problem since :D
Ahead
Post by Ahead » Sun Aug 20, 2017 10:37 am
Thanks! Just been out to the Bongo and found both short captive bolts! Will give it a go later today. I might use a tiny bit of resin in addition.
Ahead
Post by Ahead » Sun Aug 20, 2017 4:26 pm
Job done :D
Thanks for the advice. Bit fiddly to get the underside bolt in but it’s done and nice and secure again.
Post by mikeonb4c » Sun Aug 20, 2017 6:09 pm
Excellent result =D>
