However the light came back on about 10 miles later
I've had a quick read on here and can confirm that all the brake lights are working correctly and no fancy bulbs have been installed. The ABS light has been on for most of the time since, although I did stop at the supermarket for 10 minutes and when I set off again from there the light had gone off, however it came back on a few miles later. It came on whilst accelerating without touching the brakes.
My guess is a sensor or the wiring to a sensor.
I thought I'd give the diagnostics a go but can't get anything from that! Is there any particular order to connect things? I tried:
Starting the engine
Putting the wire in between GND and TBS
Putting an LED between B+ and FBS
I don't seem to get anything from the LED. Does the LED have to be anything special? I tried two random unmarked LEDs that I had but no idea what voltage they are meant for. I also tried a test lamp but that didn't light either.
Also should the ABS light flash when the link wire is put in? I think I read about the engine light doing that but I've not seen anything about the ABS light.
Thanks in advance
