Check fusible link first
imwavygravy
Post by imwavygravy » Thu Mar 08, 2018 6:23 pm
After having starting problems for over a week and checking almost everything #-o , changing the fuel filter, changing the glow plugs, changing the o-rings on the fuel pump (there was a slight leak).... the final piece of the puzzle was the relay end of things. I stripped away the insulation from the fusible link to find that it was broken/melted in three pieces. I couldn’t even feel that it had broken. I had to strip the insulation off. :roll:
I hope this helps someone. As I had been pulling my hair out for over week.
Re: Check fusible link first
Post by Bob » Thu Mar 08, 2018 6:40 pm
Useful tip, thanks. 8)
And welcome to BF. :)
Post by teenmal » Thu Mar 08, 2018 7:01 pm
Make sure that the glow plug rail has plenty of clearance from the injector pipes.
Take Care
Post by mikeonb4c » Thu Mar 08, 2018 8:37 pm
teenmal wrote: Thu Mar 08, 2018 7:01 pm Make sure that the glow plug rail has plenty of clearance from the injector pipes.
Take Care
Excellent advice. =D> =D> I was thinking that something must have been aggravating it and that seems a prime suspect to me.
