Space Saver wheel
TheLongRoad
Space Saver wheel
Post by TheLongRoad » Wed May 09, 2018 10:25 am
Has anyone successully fitted the space saver wheel in it's storage place under the Bongo with the outer face of the wheel facing downwards? This would give access to the valve to check pressure and top up if required without having to extract the wheel?
2002 Friendee 2.0 ltr Petrol.
Re: Space Saver wheel
Post by mikeonb4c » Wed May 09, 2018 12:53 pm
TheLongRoad wrote: Wed May 09, 2018 10:25 am Has anyone successully fitted the space saver wheel in it's storage place under the Bongo with the outer face of the wheel facing downwards? This would give access to the valve to check pressure and top up if required without having to extract the wheel?
Interesting idea. But...it would expose the valve etc to the elements which could be seen as a downside? So long since i dumped my space saver i can't remember :oops:
TheLongRoad
Post by TheLongRoad » Wed May 09, 2018 2:35 pm
I'm one of those folks who has both space saver and the can of sealer. :wink: Reckon I might give it a try, the Bongo is only a holiday vehicle for us... far too valuable to get trashed in the local supermarkets and salty winter roads. I'll let you know how I get on.
Post by Bob » Wed May 09, 2018 5:17 pm
Space saver and full size rims fit easily with the valve downwards.
I always make sure the valve is to the rear of Bongy so as I can check the pressure easily, and I'm not sure the road dirt would be any worse than when the wheel is on the road. :wink:
I also remove the spare every six months to check it over and make certain the winch hasn't seized. 8)
TheLongRoad
Post by TheLongRoad » Wed May 09, 2018 6:04 pm
Cheers for the replies. I’ll be needing to get a bit of paint on my space saver as it has some surface rust. Not that anyone can see it under the Bongo but I know it needs doing. :roll:
Post by Bob » Wed May 09, 2018 7:11 pm
This guy has done a good job:
https://m.youtube.com/watch?v=u-TNsO33eqQ
TheLongRoad
Post by TheLongRoad » Wed May 09, 2018 7:29 pm
Looks good. I’ll be using some Aqua-steel rust converter as well. The inside face is grim :|
